What the Heck is this??? Weird foundation
  • #31
    Re: What the Heck is this??? Weird foundation
    Originally posted by Josh View Post
    My question is... how do you seal the gaps between the sheets of blue skin? We are talking about the stuff that Henry makes right? http://www.henry.com/blue_skin_henry/
    I can't remember if Henry is the company that makes it, but what you're showing there is window and door stuff. The BlueSkin that I'm talking about is a spray-on coating - it's a blue, polyurethane coating.
    • #32
      I'm lost on where I would find this stuff and who to have do it. What equipment I would need etc. May just go with the tar stuff. Gotta get this covered up but want to do it right so still open to the idea.
      Found this nice pic.
      • #33
        This is the product I've seen as well.
        • #34
          That's the stuff, Josh. I don't do it myself, nor does my boss. We get a company that specializes in it to come in and do it when needed on jobs. So I'm not sure if it's something that you can do yourself in your area - whether or not you can rent the sprayer, etc., or whether you have to have a licenced contractor/company come in and apply it for you. It's pricier than the tar, obviously, but it's worth it's weight in gold, especially in climates like ours when you have frost issues leading to ground heaving and movement, etc. Unlike the tar, this stuff is way more stretchy, if you want to call it that, and will move/adapt with some cracking/expansion.
          Also, unlike the tar, you could, if you wanted, just go with this stuff. Yes, the dimpled membrane is a nice added barrier, and makes it perfect. But its not as needed with the BlueSkin stuff, whereas with the tar, it's almost a must.
          So, the cost can even out either way.
          • #35
            Here's some stuff that I found on the BlueSkin membrane:
            This is the sheet stuff (not the nice to apply spray-on stuff), but still the same general product:
            http://www.can-save.ca/Foundation/ba...rproofing.html
            And this is all the efficiency ratings, etc., for our building codes for the sheet stuff:
            www.nrc-cnrc.gc.ca/ccmc/registry/pdf/13297_e.pdf
            Here's the spray-on stuff, in grey:
            http://www.decoproducts.com/deco20wp.htm
            And then, after a bit more searching, is the actual stuff I've been talking about:
            www.bluesealwaterproofing.com/resources/pdf/ICFTechData.pdf
            So, it's called BlueSeal (BlueSkin, which in my experience, is the common term that everyone calls this stuff, but actually refers to the sheet version / another product / same idea, while BlueSeal is the spray on stuff). This stuff is the best IMO for your need. The biggest thing that I like is that it is rated for expansion, once dry, up to 340% - which means that even after you use hydraulic cement to patch up your cracks, if things still shift, this stuff retains it's integrity. It'll even bridge open cracks, and still retain it's seal, up to 1/16", which doesn't seem like much, but it's impressive. With this stuff applied after a powerwash and the application of hydraulic cement to patch up your cracks and openings, you'd be set.
            And here's their webpage:
            http://www.bluesealwaterproofing.com/
            All of this is our Canadian stuff. I'm not 100% sure what's available to you there in Ohio, but I'm sure if you get into contact with the company, they can guide you better for your needs on that side of the lake.
            • #36
              The end of the story....
              http://www.ridgidforum.com/forum/sho...d.php?p=256338
