basement floor waterproof
  • basement floor waterproof
    demoished my finished basement and found few corners floor are wet after heavy rain. do you have any ideas to stop/reduce the wet? heard drylok. Any other recommendation?
    Re: basement floor waterproof
    I would look to the outside of your house first. Leaking gutters, downspouts that drain too close to the house with no splash blocks to disperse the rainwater and hopefully your grade pitches away from the house. Dryloc is more for damp-proofing. It won't keep water out of your basement if it's under hydraulic pressure.
