caulking the sill plate
  • caulking the sill plate
    I have replaced the rotten sill plate in my garage stud wall and re-sheathed and sided the outside walls. Soon I will start to install the insulation and vapor barrier. Should I caulk where the sill plate meets the concrete floor? If you think so please tell me why. thanks, Andrew
    Re: caulking the sill plate
    If you plan on heating the garage, you could have used sill seal roll gasket between the sill plate and the concrete to prevent air infiltration.
      If there is no gasket then I would caulk it (air infiltration). If you are going to park a car in there and there is no slope to keep the water away from the walls I would seal it a little better and for about 3" up all the way around the perimeter
        I did use a sill plate gasket. Just wondered if a bead of caulk on junction to the floor would be a good additional measure. The garage is a heated work shop and will not have a car in it.
        thanks, Andrew
          Can't hurt. It will keep spills and saw dust out of the cracks.
          Sounds like the carport conversions around the X in-laws - walkley/russell area
