Insulating?
  • Insulating?
    What type of insulation can be installed in an existing houses walls without demoing the finished walls?
    Drilling at the top & bottom behind the moldings?
    Would spray in expansion insulation push things out?
    Thanks.
    Re: Insulating?
    Blown in
    but they have to drill an 1 1/2" hole above and below fire stops.
    Foam insulation can lift an empty tub.I wouldn't
      Re: Insulating?
      They are doing it with spray foam now. I just did a google search about it a few weeks ago. They do it from the outside just like blown in, butI don't see why it could not be done from the inside if needed.
      I can't remember the search term I used to find the info. I'll ask the FIL.
        Re: Insulating?
        Search terms: spray foam injection insulation
        may want to include Tripolymer
        in your search
          Re: Insulating?
          in your search
          So it sounds like this product is "lighter",not as "stiff" as what I'm used to see/using.
            Re: Insulating?
            Thats pretty much my guess. I don't know much about it.
            FIL asked about it a few days ago. My reply was "spray foam without ripping the walls? uuum...I don't think so"
            So he did some poking around because he swore he'd heard/read something about it.
            To me it looks much better then blown. We might try it out, but it's still up in the air.
            Looked into buying a system. Since the whole house needs to be done it might be worth just buying the whole deal. NOT. Big bucks for the systems.
              Re: Insulating?
              Dense pack cellulose may be the most economical choice. 11/2" holes high and low, inside or out. Our crews do it every day. We have the occasional nail pop but nothing major.
              They do make a low expansion foam for this application. I believe it will cost and arm and a leg or two but it could pay itself back over the years.
