sealing basment
  • sealing basment
    I have a water pipe comming up from the basement floor and there is a
    small gap about 4mm between the pipe and the concreat floor. when It
    rains very heavy water comes up from the small gap between the floor and the pipe, how can I seal it to stop the water from comming up? I did notice someone that owed the house before I did put some cement mix
    around the pipe but it came loose, anyone have any other idea's????
    Re: sealing basment
    try a can of foam sealant.
      Re: sealing basment
      I would look at fixing the water issue first then seal with silicone. You may have a partially blocked weeping tile causing water to collect at the foundation and under the basement slab - not good. Look at the down spouts and ensure there is proper run off away from the foundation
