Soffit repair
  • Soffit repair
    I've got to repair squirrel damaged Soffit and Fascia. The Fascia isn't a problem; that one I can handle easily. My problem is the soffit. It appears to be some sort of laminated hardboard with a smooth paintable surface. Does this material have a name, or should I simply replace with 1/4" ply and live with the difference? I can't quite tell how thick the current material is; perhaps 1/4"? I'd rather replace it with similar material.
    Any advise would be appreciated.
    Re: Soffit repair
    Sounds like MDO . It has a very smooth almost hardboard face with a plywood core. Best of luck
      Re: Soffit repair
      Thanks for the reply, but the material is not MDO. It's some type of fiberous pressed material, kind of like rigid cardboard.
        Re: Soffit repair
        Used around here in the late '80's --late '90's, or something very similar. Junk in my opinion. Usually stapled in around here, staples rust, fall out/break, and the soffit comes down. I replace it with plywood after determining which thickness to use. Prime twice before putting it up. But then, I have the time. David
          Re: Soffit repair
          As said above just find out how thick it is and replace it with plywood... No difference then.
