Telepost
  • Telepost
    A friend had a new house built for them 2 years ago and I noticed that the plate on the telepost is bent.
    From the picture do you think this is something to be concerned about?
    Thanks in advance!
    Re: Telepost
    Absolutely.
    It looks like it is heading towards kicking out. There's probably considerable weight as well on that beam.
      Re: Telepost
      I would not want that on my house, looks like a failure that could happen to me, and it looks like it is in a location that if the post does move you will have some serious issues to deal with,
        Re: Telepost
        Originally posted by DUNBAR PLUMBING View Post
        Absolutely.
        I agree! It can be remedied, but I wouldn't wait too long.
          Re: Telepost
          I don't know if your local code permits that type of support in lieu of an actual header, but I suggest cement filled lolly columns as posts.
          If that is acceptable, I recommend LVL's for the built-up; each terminated joist should be attached securely & blocked.
