Removing window sash pulleys
  • Removing window sash pulleys
    I'm replacing my old double hung windows with new insert windows. The project is easy enough with the exception of removing the sash pulleys. Sometimes they come out with a little pulling and a good yank or two. Other times it is a full on fight to get them out.
    There are no screws on the pulleys, they seem to be held in place by a series of teeth. The picture does not show the metal tabs that trim the pulley (they were pulled off in the struggle).
    Anyone have experience removing similar pulleys? I know that I can just beat them into the cavity, but want to use the opening to insulate the space where the weights are.
    Thanks.
    Re: Removing window sash pulleys
    Do you have weight pocket doors on each side jamb held in place by a couple of screws? If removing the pulleys from the front is too much of a struggle, you can beat them into the pocket and retrieve them through the weight pocket doors. With the pocket doors removed you can insulate up through them and down from the pulley holes.
      No, it has a solid jamb.
        Some of the pulleys come out with a fight, but they built things to last in those days. If they were to build/install those now a days, I'm sure you could just look at them funny and they would fall out.
        TIP: when insulating the pocket, the end of a nice flexible fishing rod helps to push the insulation up/down.
          Agreed. After 100 years of holding sash weights and windows, these things don't want to go anywhere.
          Great idea on using a fishing rod! That will save my dowel stock. Thanks.
            FYI,
            I drilled holes where the teeth are located and it was much easier to remove the pulley.
