Condensation on windows
    Re: Condensation on windows
    HVAC HAWK... you seriously need an explanation on window condensation?
    The next time you're confused about where the moisture is coming from, close your mouth and stop breathing...
    Install a HRV like the fellow 2 posts up said... you are an HVAC guy aren't you?
      Crack a window at night !
        [QUOTE=dlarrivee;387690]HVAC HAWK... you seriously need an explanation on window condensation?
        Install a HRV like the fellow 2 posts up said... you are an HVAC guy aren't you?[/QUOT YEA BROTHER , YOU HAVE IT RIGHT !
          I wanted to firs see if the window had a problem because it only happens on some windows . Im not going to run a dehumidifier . I do crack a window all the time now because if the house is that tight I need make up air for the wood stove .As it is getting colder out it is also getting dryer and its not as bad in the house
            If it's only on a few windows maybe the "seal" is faulty between the glas panes. I have one window with that problem
              Its not inside the window but at the bottom on the inside .Its getting better now
                Originally posted by lreops View Post
                Maybe a portable Dehumidifier (around $100.00) would be a choice to consider.
                Ron
                I just purchased one that uses a standard water bottle. Very effective!
                ____________________
                "I have busted more hippies' noses than all the narcs in the free world." - Ted Nugent
                Chuck Dee - AKA Chris
