Water leak from top of basement door
  • Water leak from top of basement door
    IMO it's not likely that its coming from the roof, but it is a safe bet that that the water is getting behind the brick at the base of the windows where the siding starts. The wall behind the brick is protected by #30 felt paper so nothing would be leaking there as long as the felt paper sheds water, but when the water runs down that felt and reaches the door, it would appear at the exact spot you have the leak.
    Re: Water leak from top of basement door
    May its just because windows are not properly insulated. The water is condensed on the windows and gradually dripping down from the windows and accumulate down there.
      I'm totally agree with you.You'r 100% good here that may its just because windows are not properly insulated. The water is compressed on the windows and progressively dripping down from the windows and acquire down there.
      Wide Range of Oval Pools | Above Ground Pools
        According to me some measures would be taken in order to repair the windows. Because the water is dripping down from the windows, So, until and unless the windows will not be repaired, this problem will occur for long.
        immobilier neuf Corse means a new real estate property in Corse.
