How To Post Images
See more
See less
Sheetrock tape-
  • Sheetrock tape-
    As mundane as this may seem-for the past several years I think about this while taping; once sanded 7 painted it's out of mind until the next time:
    I seem to recall in the mid 80's, when I first began taping, paper drywall tape had very small perforations.
    Am I mistaken?
    Re: Sheetrock tape-
    You are right.
      Re: Sheetrock tape-
      yes I remember seeing it never used it, only a few times, the thing I did not like was he mud would squeeze through and there would be little bumps to sand off,
      I have never done any wet wall (plaster with a dry wall type backing), but was it for the joints on a wet wall application?
      I know most of the mud used to day is more sticky than some of the first joint compound I used, some of the first compounds were very dry acting.
        Re: Sheetrock tape-
        I remember it but never used it. I did use the sticky gauze tape, but I prefer the plain common paper.
          Re: Sheetrock tape-
          Let's talk about this too.
          Always used Sheetrock brand all-purpose mud if I wasn't mixing hot mud. I have also noticed recently, even though I am bench-pressing as much and more than ever, 5 gallon pails are much heavier than they were!
          Also, whereas I would sometimes use a damp sponge in lieu of sanding( popcorn or knock down), lately this stuff is a bear to sand!
          So, whereas the tape is a factor, perhaps it is the mud which has changed the most?
