Max beam span kids fort
  • Max beam span kids fort
    Hi. Thanks for everyone's advice on my post situation. My question is now this - I was going to use 12' long double 2x10" beams to span 11' between posts. After some pontification I've come to the conclusion that won't be enough. Will double 2x12s work? Triple 2x12s?
    Re: Max beam span kids fort
    I'd have to see your plans, could you post a drawing?
      Ended up using 3 2x12s on each side to cover the 11" span. Should be sufficient
        Good luck on your fort
          Post up pics of the progress!
            All depends on the wood used, the calculated live (max number of kids) and
            dead (weight of fort components that bear on the beams) loads, and maybe more
            important, how you connect the beam to the posts (nailed, bolted, joist hangers, etc.).
            John Ruskin (1819 - 1900)
              I think he is building it to withstand a 105 Howitzer!
                Lets see , what size tires for My vehicle ? Vespa Scooter or Lincoln Town Car ? Doubled up , back to back 2"x12 " channel iron should be safe . Skip weld with 3/16 " 7018 every 6 "
                  A W12X22 beam should span 12 feet of children playing just fine....LOL
                    a typical re-enforcing trick we use is to sandwich a plate of 1/8 steel between the 2 x 12 (the 2x12 keep the 1/8 plate from bending) and this arrangement supports a lot of weight
                    coffee hell gimme booze!!!
                      Called a flitch plate.
