Paint Removal tool options
    Ben 2 months ago I did a redwood deck with turbo nozzle . Only way !
      Since this thread is over a year old, I'm sure the job is done.
        I ended up buying dewalt 13" planer.
          Pictures ?????????????
            https://www.google.com/search?q=pict...ed=0CAYQ_AUoAQ
            Here you go......
            • toolaholic
              toolaholic commented
              Editing a comment
              Ben You just gave Me the biggest smile at 4: 33 AM ! Thanks ,It's gonna be a good day! Kevin
            Jet it man...lol
              Hand planer works fairly well,also #60 grit paper with a 7 " grinder,if you can still find that grit any longer.
              • #23
                I guess 'Thermal' methods are excellent for removing multiple layers of paint. If the previous paint is peeling, cracking or alligatoring removal by use of thermal methods is often times the best choice. The procedure for removing paint is fairly simple; heat the paint till it bubbles and scrape it away. While you’re scaping away the paint move your heat source to the next area. When using thermal methods for paint removal you’ll want to wear protective gloves, eye wear and a respirator. You will also want to cover the ground with plastic to contain the removed paint.
