Replacement Windows?
  • Replacement Windows?
    Any recommendations and/or brands for replacement windows?
    Thanks.
    Re: Replacement Windows?
    I dont know brands. However, when working for the last hack...err... boss, I found that the more expensive the windows are, the better quality they tended to be.
      I just purchased Reliabilt 3500 series double hung windows from Lowes. They are Energy star rated, have an aluminum frame underneath the vinyl and were of good quality for the price. I did 15 windows in a duplex with them, most 30x70 or 34x74 so they are big windows. I looked at a number of other suppliers but all were much more expensive or not of as good qualtiy. I was specifically looking for strength due to the large size of the windows.
        Do it right the first time!
        I replaced some single pane aluminum sliding windows with
        Pella dual pane vinyl windows I've had them in now about 3 years
        Not a single issue..outside noise level significantly lower, yelling inside is not heard outside ha ha
        The difference in heat or cold loss is significantly cut!
        I was tempted to buy a "brand-X" at a local big box store but decided
        this was not the place to be cheap! since this is not something you want to
        change often!
        No Regrets,
        Cactus Man
          Jeldwin produces a nice window. Slightly upscale but all the options, i.e. argon, low E glass etc. are available. I put them in my house, new construction, not replacement, but the windows are the same. Buy from a lumber yard not the big box stores. Just my 2 cents.
            Anderson, Pella, and Marvin--all good brands. all have been in business for a looonngg time. Can't go wrong with any of the three.
              The Reliabilt are made by Pella for Lowes apparently. These were low E Argon filled, aluminum framed vinyl cald double hung half screen. The 34 x 74 were around $220 each. They also cut the noise adn cooling loss noticeably. We will see over time how they hold up, in a rental you can't get much more severe abuse. Time will tell. These replaced Owens Corning Care free windows which were a complete piece of junk. I almost considered the Anderson fiberglass windows but there were some reviews of them delaminating in a few years, and I know vinyl has a good record for holding up to the elements.
                Jeldwin if your in a cold area.
