Roofing shingles all overlap but what type do I choose?
  • Roofing shingles all overlap but what type do I choose?
    I am getting ready to put a new roof on my home. There are so many types of shingles. They all seem to overlap in sections. How do I decide what type of shingle to use? I did some research that I want to share with you. Below are several types of shingles but I'm sure there are many types not listed. If you know of others, please add them to the comments below. In the end, I know I will call Barton Roof for more information and ideas specific to my home. But at least I will be a little more educated when I call.
    Solar shingle
    The first thing I want to look at are solar shingles. Energy savings and leaving a very small footprint is very important to me. Solar shingles or solar panels or solar modules, depending on where you look, typically look just like a regular asphalt shingle. They can be made to fit together well, are durable and are easy to install. The roof needs to have a pitch of 3/12 or more. They are comparatively expensive but they do have a long life.
    Asphalt shingle
    Asphalt singles are the most common roofing shingle in the U.S. They are easy to install and less expensive than most shingles. They are one of the fastest installations, sometimes removing an old roof and putting up the new one can be done in less than a day. However, oddly, they are virtually unused elsewhere except in the outhouses in Europe. They are made of bitumen covered with a ceramic grit that can come in many colors. You must have a slated roof.
    Wood shingle
    Wood shingles are made from tapered thin pieces of wood, like red cedar. The problem is that if the red cedar is young, the life expectancy of the wood shingle is much shorter than if the red cedar is older. With the older red cedar, the life of the wood shingle roof can be up to 30 years. Bolts of other hardwoods including white cedar can also be used. Wood shingles are sometimes used on walls as well. The early North American colonies used wood shingles for most of their roofs and Scandinavia used wood shingles more than anything else until the 1950s.
    Shake
    Shake shingle are made from logs that have been split. Shake shingles typically gives a rougher appearance and are used worldwide still. They require weatherproofing and more maintenance than a lot of other shingles.
    Ceramic tile
    Ceramic tile roofing is lovely, creating a beautiful roof that can last more than 100 years, however, it is very heavy, requiring a very strong support structurally and it comes with a very high price tag.
    Slate
    Slate is actually a rock made of clay or volcanic ash. It has a life expectancy of up to 400 years, but it comes with an enormous price tag. Australia, Bethesda, Wales and Spain produce the highest quality slate.
    Home improvement news brought to you by bartonroof.com
    Source: en.wikipedia.org/wiki/List_of_commercially_available_roofing_material
    YOU forgot metal roofing options,
    a lot depends on what one can afford, and the conditions in which /where one lives, if hail is common, wind and such, snow, etc. even fire resistance.
    look around your neighbors roofs and that will give you guide as to what is common in your area,
    but I am not sure if your really wanting advice or just blogging/spaming
      You did a pretty good job of disguising your spam post that promotes Barton Roof as a question about what roofing material to use.
        I like to use old records. Overlap and nail through the hole
          Like BHD mentioned, metal roofing is an option. I used to consult Empire Roofing Corporation. Everything depends on what one can afford. Once you have an idea on how much you can afford, then plan accordingly.
            Old records will NOT work around here the hail breaks them up to fast, so we use old license plates, there much tougher, but it is getting harder than it once was when they went to mulit year license plates with the little stickers, on them, still saving for the garage, and the aluminum plates are not as trough as the old steel ones,
            Like I said in my original post on this subject, you had not considered metal roofing options,
              More types are Wood shingles, Slate shingles, Tile shingles. There are different types of metal roofing like tin, copper, aluminum. My brother choose metal roof repairs Fairfax, VA because that is eye catching therefore, it makes home look elegant.
                Originally posted by nationscons
                You did a pretty good job. But you missed out on Fibreglass shingles and organic shingles.
                I would consider them a type of an asphalt shingle,
                  And on that note I would recommend Rustic Shingle.
                  Distinctive colors coordinate with any home
                  Concealed fasteners hold tight and never weather
                  Rugged texture with realistic wood grain
                  Maintenance free: will not rust, crack, or rot
                  Resists streaking and staining
                    If you want to compare shingles than metal shingles, you have to add more value for the expense. The metal shingles go on much like regular shingles and their structural warranty last between 50 and 80 years. The Construction Contractor will have to investigate everything about the building and the budget of any company owner.Anyway On the other way the Asphalt shingles structural warranty lasts 25-30 years and the color of asphalt shingles lasts about as long as metal shingle color. The cost of both is deferred but the pattern will be the same I think so of installation, Metal shingle 10 times costlier than the Asphalt.
                      Leave the job to the professionals.. Not sure if you were planning to try to figure out how to install the roof yourself but it doesn't sound like you're very knowledgable about the application and quite frankly roofing can be dangerous if you're inexperienced. The type of roof you get depends on your budget, as the difference between an asphalt shingle roof and higher end materials can be tens of thousands of dollars.. If you're working with a professional company they will walk you through all of your options.
                        Remember the Pancakes on Green Acres?
                          Depending on the sort of weather you experience and, of course, your budget, I'd look at metal roofing applications as they're much more durable and will need less maintenance over the years.
                          Better still, they're less susceptible to adverse weather such as heavy snow, wind or rain.
                          If the weather where you live is good, my preference would be wood shingles as an affordable option. However, if you're happy to spend a more and don't mind the maintenance, ceramic tiles which are, without a doubt, the best looking.
                          ParadiseHome - Loft Conversions London
                            This might add and give you more ideas to consider. https://www.consumerreports.org/cro/...g/buying-guide
                            ________________________________________________
                            Pest Control DC
