So I'm building a wine cellar in my basement and wanted two walls done with reclaimed brick (about 2x10x5/8" thick).
I will be screwing wine racks onto the brick, and the guy I was using to do the brick laying suggested putting a 1/2" plywood onto the drywall to provide extra support for the wine racking.
So I put up the plywood. He came by today and was going to use Omnigrio to apply the brick directly into the plywood.
But I read up on Omnigrip and saw nothing but nightmares from folks who used it.
So now he's suggesting metal lathe on the ply and a thin coat before applying the brick with thinset.
But I'm pretty nervous after his first suggestion.
Should I install maybe a 1/4" Cement board onto the ply and then thinset the brick onto the CB instead of the metal lathe?
Racks will be like the ones in the puck below. Except 2 to 3 bottles on each rack (I. E. It will come out 2 bottles at top and 3 bottles at bottom).
