Micro Seesnake
  • Micro Seesnake
    Ok now what??? I went to move the head and it broke off in my hand...errrrrrrrrrr I was working on a water closet as some kid tried to flash GI-Joes head down. I took it out of the case and went to move the camera head and it snapped off. I dont think the plastic head is gonna last long if it brakes off in your hand moving it.
    Re: Micro Seesnake
    I heard that it takes very little pressure on the end to snap it off.
      Re: Micro Seesnake
      you heard right
      I guess I`ll send it in and see what they say.
        Re: Micro Seesnake
        Good luck on that. My friend just ended up buying a new one. he had to replace for the company he worked for. WARNING DO NOT BEND AT END WILL BREAK WITH VERY LITTLE PRESSURE!!!!
          Re: Micro Seesnake
          I wont buy another one if they dont take care of it
            Re: Micro Seesnake
            wow thats not good
            i was looking to get one ,is the head made to move
              Re: Micro Seesnake
              that really doesn't look/sound like a product design that is Field Friendly.
              hope they make it good for you
              steve
                Re: Micro Seesnake
                all clear. do you run the micro into toilets and into the trap of them?
                seems like you have another weld issue
                i've only run mine into a wall cavity so far.
                  Re: Micro Seesnake
                  I wonder if the camera was over-tightened on the wand when it was assemblied and it caused damage to that connection?
                    Re: Micro Seesnake
                    It`s just thin plastic and will not support adjusting if you adjust the camera from the head. I think they should be made out of stainless steal to support adjusting.
                    Rick
                    yes you can run em to the open air pocket but you cant or shouldn't try to go all the way in the trap. I turn em over to look in the other side if I cant see anything from the top. Works pretty good for working on W/C`s.
                    i was lost with out it when it broke
                      Re: Micro Seesnake
                      I use my mini see snake for toilet traps, but the micro would be more convenient as long as I don't break the tip, which with my luck will happen. using the micro for wall cavities and such, where I don't have to break a large hole is great. let us know how it works out
                      Robert
                        Re: Micro Seesnake
                        Is that end red? The end on the one I just got is black.
                          Re: Micro Seesnake
                          it`s orange
                            Re: Micro Seesnake
                            it`s orange
                            Ok I am color blind. But the one on mine is black. Just wondering if it is an update or not.
                              Re: Micro Seesnake
                              Hello everyone,
                              I am the product manager for the See Snake micro. You probably want to steer clear of pushing the camera head all the way through a toilet trap. You would likely have to use a significant amount of force, which could lead to damage. Even if you worked your way through the trap, it may be extremely difficult to pull it out. Unfortunately, in tight spaces like these, the camera head is going to bear the brunt of whatever force you are using to push or pull on the cable. Do not yank on the cable or use excessive force to insert or bend the cable.
                              I can assure you that we will stand by our warranty on this product like any other Ridgid product. If you feel that your problem was caused by a defect in material or workmanship, contact an authorized service center or our tech service department
                              Talk to you soon!
