Need a Locator for PVC
    Re: Need a Locator for PVC
    When you Bury They also make a tape that has a metal backing on it. Depnding on how deep you go it will also alert other diggin in that area there is some thing in there when they hit the tap and not the pipe first
      yep it works. I've done this before, run a cable down thru the pipe and connect your energizer to it to locate the cable which is acting as an antenna. but yes anything metal would work. run your fish tape down there and use it forget the wire.
        welcome to the forum mtnman!
