slip ring problem
  • slip ring problem
    I own a kd325 seasnake that is 14 months old and has picture quality problems while rotating drum. Service Agent thinks it is a slip ring problem........How common is this problem, how long should a slip ring last?
    Re: slip ring problem
    i've never worn out a slip ring.
    does the picture jump around when rotating the drum, and not moving the camera down line? is the drum tension knob too loose?
    i was under the impression that the slip rings were tested to 1 million rotations
    you need me to bring you a back up camera to australia how's the weather there i need a vacation.
      Rick
      Weather is good thanks start of summer. Yes you are right if you feed the camera out of the drum you get a lot interference if you pull out the cable first then run it down the drain with out rotating the drum it is ok. I think that they will most likely replace the part under warranty..... I take it from your experience that the slip rings normally last longer than a year or two. Do you give your camera wash now and then is the drum not to get wet ??
      My concern is that i have looked after my gear and it is playing up is there any tips to looking after your gear
      Pipeline Imaging
      Steve
        Steve,
        You missed the most important part of Rick's thread. . .we can bring you one to use in the meantime
        Weather prevented us from choosing to go to Australia for our honeymoon.
        Joey
        I love my plumber
        "My Hero"
        Welcome, Phoebe Jacqueline!
          Originally posted by MrsSeatDown View Post
          Steve,
          Whether prevented us from choosing to go to Australia for our honeymoon.
          Joey
          Whether Rick wanted to go?
            No seriously, weather. We got married the end of April and it is the start of rainy season there.
            Rick wanted to go to along with New Zealand. It just didn't work out.
            I love my plumber
            "My Hero"
