swimming pool lines
  • swimming pool lines
    Does any one know how good the mini works on pools? will it make it through bottom drains ect . Or should i use sound? And repair methods dig a hole, epoxy liners, recliner systems
    i would like to keep decks intact
    Pool lines are usually 1 1/2" or 2" lines older pools use polyethylene black pipe
    Newer usually tiger flex
    Re: swimming pool lines
    While I have never used my mini in a pool drain it seems the limitations would be the fittings not the pipe.
      out here the older pools are copper and the newer ones are pvc. i have done some pool lines and as long as they use a 45 and not a 90, it's fine. i pushed once 190' in a 1.5'' pond line with 3- 45's.
      the white pipe / pvc has better resolution than black pipe.
