100mm Traps
  • #31
    Re: 100mm Traps
    When you click "post a reply" write what you want then click "manage attachments" then go to "browse". This will open up your files, click onto your pic then you should be back on the page that says browse and upload. click upload at this point and you're done.
    • #32
      Re: 100mm Traps
      Gear junkie
      Testing one, two, three
      • #33
        Re: 100mm Traps
        Do you have P-traps or S-traps throughout a residence or business on the greywater drainage (sink, shower) that goes to these boundary traps?
        • #34
          Re: 100mm Traps
          i can't get your photo to open into a larger frame.
          i guess it's a start.
          • #35
            Re: 100mm Traps
            Mark ,We have whole house [ street traps in SF ]
            • #36
              Re: 100mm Traps
              Do you also have traps throughout the residence/buildings?
              • #37
                Re: 100mm Traps
                Firstly thanks AFM for the guide mate I havent had a chance yet but Im sure this will work. Secondly I cannot get into the explanation to these Americans but I will say to all of you US folks this. Are you READY!!!!!!!!
                All fixtures be it a shower, basin, toilet etc have a trap directly connected to them. With exeption to a larger trap for floor wastes or dt's, where multiple fixtures can be connected under certain rules only. A lot of sewer systems here also have the (* BOUNDARY TRAP) at the connection to the sewer main.
                • #38
                  Re: 100mm Traps
                  Testing 1, 2, 3,
                  • #39
                    Re: 100mm Traps
                    Rick
                    I have tried it again does it work ??????????????
                    Tony
                    • #40
                      Re: 100mm Traps
                      Yes on all pre 1976 plumbing systems in Melbourne where I live and which are in the millions in Australia.
                      But since 1976 they modenised our plumbing system, where only one disconnection trap which is called an ORG (over flow relief gully) are needed and boundary traps were deleted in 1960.
                      But before then all pumbing fixtures had a individaul trap and then drained into a disconnector trap which was placed in the ground ontside the building line and then drained down the sewer pipe into a boundary trap which was connected directly to the main sewerage pipe at the boundary of the property and that is why it is called a boundary trap and a shaft was extended to ground level to vent to sewerage pipe and for access for cleaning a blockage.
                      Tony
                      • #41
                        Re: 100mm Traps
                        Originally posted by AFM View Post
                        Rick
                        Tony
                        nice wheels on your seesnake
                        are those the standard for overseas, or an upgrade by you
                        yes the picture works
                        • #42
                          Re: 100mm Traps
                          Excuse the ignorance. Can anyone explain to me why one of these boundary traps or curb traps is a good idea? Sewer backup maybe, but it seems like a bad way to do things. Yank'em & put in a backwater valve?
                          Thanks.
                          • #43
                            Re: 100mm Traps
                            Rick
                            Arn`t they nice Rick compared with the cheap plastic rubbish Ridgid puts on their equipment and then calls them wheels, I have the same on my K-1500 machine as it makes it a lot easer to move from one place to the other, you would think that the money we pay for Ridgid tools you would get the best but we in Australia we improvise we over come and swear till the kangaroos come home.
                            Tony
                            • #44
                              Originally posted by NHMaster3015 View Post
                              Seriously Man, need to see what you are talking about.
                              The white pvc trap in the back is a boundary trap as they don`t make them in earthenware anymore and the cast iron one in front is a disconnector trap.
                              The reason for having a boundary was early last century the powers to be were paranoid about sewer gasses getting into the house hold sewerage pipes and the boundary trap was the first line of defence it had a shaft extended to ground level and had a vent on it called a ground vent.
                              Tony
                              • #45
                                Re: 100mm Traps
                                Running traps were, and are still used for a purpose. You boys need to go to school, or back to your union jobs where you'll have some sort of supervision...
                                Removing running traps is a no, no.... Hope ya'll don't kill someone..
