No clean outs sewer location tip
  • No clean outs sewer location tip
    I use my k3800 hooked to my sonde to locate sewer lines. But when there is not a cleanout I have to pull a toilet. Is there another way to get my sonde through the toilet with out pulling it?
    Re: No clean outs sewer location tip
    no
      Get a flushable sonde or go through the vent.
        i've used flushable sondes in the past and sometimes they don't pull back as the string will snag and break.
        the vent would be the easiest if you use a fiberglass push rod.
        there are no cleanouts anywhere on the property? even a 2'' sink c/o?
          CORRECT! No cleanout anywhere.
          I see this on many older homes in Phoenix. If they do have clean outs they were added after the fact.
            Thanks guys. I will get a flushable sonde. I do not have a fiber glass push rod and I have hualed my drain snake up there before....... that is touch to do!
              why would a handyman need to locate a sewer or drain??
              Robert
                The guy wants to add a cleanout. The house currently does not have one clean out.
                  So he can take work from licensed plumbers.
                  Regards
                  Tony
