With Inspection In Cañer?*a Methane Gas
  • With Inspection In Cañer*a Methane Gas
    We must do a diagnostic service in a methane gas pipe where it circulates. The filming is done with closed plumbing and gas circulating. The question is: is it possible to make it or it runs the risk of an explosion? The methane gas damages the plastic ring which covers headed? We are grateful to all those who can answer these questions.
    Always thankful
    Cloacas Argentinas
    Re: With Inspection In Cañer?*a Methane Gas
    Sewer Gas is a complex mixture of toxic and non toxic gases that can be present at varying levels depending upon source. It is formed douring the decay of household and industrial waste. Highly toxic components of sewer gas include hydrogen sulfide and ammonia. Sewer gas also contains methane, carbon dioxide, sulfer dioxide, and nitrous oxides. In addition, chlorine bleaches, industrial solvents and gasoline are frequently present in municipal and privately owned- sewage treatment systems.
      I am grateful for his extensive response. I understand from the same composition and the source that originates gas. We need to know if you perform the service with gas in the pipeline could damage the camera, the plastic ring and whether to serve with the gas flow can be explosive or not.
      Cloacas Argentinas
        It can
        It is the principal component of natural gas
        Methane is a colorless, odorless gas with a wide distribution in nature
        Hope this helps
        Link below:
        http://www.youtube.com/watch?v=PC31eXovlEI
          All clear Sewer: Thank you for a video show as explanatory, I stayed clear its response
          Cloacas Argentinas
