Picture Quality
  • Picture Quality
    Why is the picture quality better in transmitter mode than normal mode on my Seesnake plus when inspecting a 4' sewerage pipe.?
    Tony
    Re: Picture Quality
    tony, that is just the opposite of what it should be.
    the transmit mode should create a series of horizontal lines on the monitor.
    well maybe vertical lines down under as you guys do everything back wards there
    see, that's why your picture is better when in transmit. ridgid is just screwing with you. that's why it's called "pal"
    not "ntsc"
    i'm sure ridgid will back me on this
      Re: Picture Quality
      I agree with Rick. The picture is much better when the trasmitter is off.
      Could you let me know why the picture looks better? Clearer? Better Color?
      or are the wavy lines just soothing to you when the transmitter is on
        Re: Picture Quality
        Once you turn the transmitter on you get interference in the video signal so I'm not sure why your image would be better with the transmitter on.
          Re: Picture Quality
          When I turn the control knob from transmitter mode to camera mode and adjust the dimmer the picture goes from clear to a grainy darker picture and I am wondering if my Monitor is set up properly.
          In the manual it says, that THE SOURCE SELECTION FOR THE LCD+MONITOR SHOULD ALWAYS BE SET TO AV-2 REAR FOR U.S. MODELS AND SCART FOR EUROPEAN MODELS, but my monitor is set for SCART and if this is not right I cannot change it as in Australia we have the PAL system so is the European system the same as Australia.???
          Tony
