Frustrated; calling all camera techs
  • Frustrated; calling all camera techs
    I have a recurring problem with a mini color toolcase. It is about 2 years old. It has been back to Ridgid at least 3 times with this problem. Got it back again a few days ago and yesterday it worked for half a job then quit.
    When I turn the dimmer switch to locate, the little satellite icon comes up on the screen, but the diodes on the camera head wink out and do not come back on, and I have no transmit signal. It has had mutiple dimmer switches replaced, and a new av board.
    I have 2 toolcases, one of the aluminum boxes, two mini color reels, a b/w camera, and 500' of the flexible wire, not a pushrod, that I use with a skid for long lines. All cameras/reel work on other toolcase and silver box. None work with the problem toolcase. Hence I believe the prob is in the tool case.
    The only reason I wasn't absolutly screwed out of hours of work getting 500' of cable pulled through a line to camera, locate, and record yesterday was that I have learned not to trust this box, and had the others with me. I got semi-screwed anyway as I switched to the other toolcase and found out after the fact it has decided not to record audio.
    Has anyone else had this problem?
    The second tool case has developed an odd thing where it gives me a blue screen unless the power for the vcr is turned on... hit the power button on the vcr and it sorts out and works. Also it is apparently not recording audio anymore, though that is new and the blue screen/vcr power thing has been going on a while. Anyone seen this before?
    I am bringing all to roundup and hope to get some resolution to this there. If I cannot, I'm giving up, its all going on ebay, and I am going with another brand. The stuff is worthless to me if I can't expect it to work. Sorry for the semi-rant... I'm just so frustrated.
    Re: Frustrated; calling all camera techs
    ace, i'm not sure if bringing it to the roundup is going to achive results.
    you might want to call and see about sending it in early so that maybe you can have it repaired and take it home with you after you give it a once over.
    i believe that the seesnakes are still serviced in san diego, ca.
    a call would be better than a post
      The only ToolCase issues I have had with my two were a dead battery, a remote stuck in the VCR and a lost signal to the screen.
        Please tell me one of the grandkids did this and not one of your guys
        I love my plumber
        "My Hero"
        Welcome, Phoebe Jacqueline!
          No as far as I am concerned it is a design flaw of the ToolCase. They store the remote using Velcro directly over the door to the VCR. When the black case of the ToolCase gets hot the glue on the Velcro gives up the ghost and the remote drops into the door of the VCR. Then when you attempt to insert a tape it will not work so you call Tech Service and they say "oh I bet the remote dropped into the VCR door". Then you say "oh maybe I will get rid of the remote I've never used" and the problem is solved.
            Just got a call from Aaron in San Diego, maybe an hour after original post. He was forwarded the post. Discussed at length and have a plan. Astounded at the response, a big thank you to whoever forwarded and to Aaron. This forum is an amazing resource. The best.
              aaron was the guy i was referring to when i said san diego.
              it was probably josh that forwarded the post to him.
              aaron is also a moderator on the forum.
                KUDOS to the SeeSnake guys. They have always been there when I needed them and I have always been able to call them from the field to get a response. It always helps when you're on a job wondering what to do next and you know they are only a phone call away.
                  Reading Ace's post made me wonder. How often do you repair your sewer camera? And at what average cost?
                    My total cost in the last 10-years of using SeeSnakes is an $80 shipping fee.
                      Mark ,can You explain those handsome Lads in Your Photo ?
                        2-3 times a year for the past 5 or 6 years.
                        Never less than $300 some over $500
                        Started with 300 feet of line; down to under 200 now
                        Yes, it's a Ridgid SeeSnake
                          Rather than going OT I updated my Avatar post with the info.
                          http://67.212.161.167/~bennettf/foru...601#post140601
                            Wow is this all stuff that happened while you were using the equipment?
                              You seen surprised
                              No the problem is we have several gorillas that don't understand how to use the equipment properly.
                              They use the monitor as a seat to eat lunch. Try to clear stoppages with it. Push it around 3" traps and 2" 90's. It's NOT a mini
                              Then put it back in the tool locker broken and say nothing. I grab it for a job only to find out that it doesn't work.
