battery life?
  • battery life?
    i find the power supply/wall wart for my Color Compact to be really cheap looking and i see it being a liability. so i guess i'll be using battery power. what kind of life can i expext from a fully charged battery with the LEDs at full brightness? how about with the sonde energized as well?
    data that i wish was published somewhere but i can't find
    steve
    Re: battery life?
    When I had the B/W Compact I got a lot of hours use out of the battery, but I always had the power supply with me and charger, so if power was a hassle used the battery next job use the power supply etc. So I don't know how long I got but it seemed like a lot of use. But I always charged it on the weekend to start the week fresh.
    Seattle Drain Service
      Re: battery life?
      bump
      no other replies?
      how about it Ridgid folks. how long is the battery supposed to last?
      steve
        Re: battery life?
        I've ran my unit at shows for 4 hours, full LED intensity on a battery. I've never timed it completely till it died though. Hope this gets you headed in the direction your looking.
        Jeff
          Re: battery life?
          Also being a little more specific Mine had the Makita Battery (blue not the red) I think 14.4 volt what battery do you have? What comes stock on the unit? Is it a Ridgid battery? Almost all the people I have seen with the compact have Makita batteries. And if you want to run on just battery power then you need a couple batteries at least. Anyway a stated battery life only works in a perfect situation meaning fully discharged fully charged tempurture or even a good or bad cell to begin with. I think you using it in the field will be the altimate test.
            Re: battery life?
            i thought this would be a published spec.
            i've got 2 red makita 14.4v batteries. i'm just looking for an "averge" time from a fully charged new condition battery. i'd hate to get on a job and suddenly run out of power.
            my follow up question is regarding the wall wart power supply. any bad experiences. i just can't see this thing lasting. i swear my cell phone charger/supply is more heavy duty than this.
            i'll probably get 2 more batteries and be ready ... just in case.
            any recommendations for an inverter to charge them from the van?
            steve
              Re: battery life?
              The factory power supply never gave me any problems. As for an inverter I bought a Coleman 1500 inverter because it had really good cooling (read the fan makes lots of noise) But it has a reset on it lots of the others don't have a reset. I use it for my cordless tool charging and my laptop and phone.
