Battery Life
  • Battery Life
    I have a Navitrack Scout and a Navitrack Brick and the battery life of each is crap.
    I use the Scout and the brick a couple times in one week then not for a couple of weeks and find I am having to replace the battries and am wondering should I remove the battries when not in use.
    Tony
    Re: Battery Life
    i have a Scout and have only to replace the batteries about 4 or 5 times in 2 1/2 years. but i also turn it off between "locates" since i work alone. now i replce the battery in the sonde on every job. it's not worth the agrivation to have a failure when for less than $1 i can have security.
    also if you have hte contrast/sound, etc cranked it will use more battery.
    steve
      Re: Battery Life
      steve
      Thanks for your imput by your calulations your changing your battries every six months but I`m getting nowhere near that with my scout and yes I do turn it off after every use, the battery in my sond that I connect to my drain cable has not been changed since I bought it six months ago.
      Tony
        Re: Battery Life
        Tony
        interesting Tony. BTW i keep lots of batteries in the van ...just in case.
        steve
          Re: Battery Life
          AFM I have a Navi Trak and had troubles with the battery life also. They were going flat between uses. I spoke with the Ridgid man and they fixed it.
          Apparently it was a dodgy transistor or something but I guess that it is useful to have the lifetime warranty.
            Re: Battery Life
            Welcome aboard the forum it gets lonely here with all these Americians but I suppose its an Americian forum and you carn`t have everything in this life but mybe in the next.
            Thanks for the advice I`ll get Ridgid to check it out as it is driving me mad which isn`t hard.
            Tony
