Seasnake and Drain cables in same pipe
  • Seasnake and Drain cables in same pipe
    Hi all
    I am looking to the Hall of knowledge here if this is a silly thing to do or if you guy's regularly do this.
    I have a Ridgid 1500 drain cleaner and in the past if I am using a camera (naturally seasnake) I have pulled out the cables because I am a bit scared of the spring head getting caught in the sectional cables or something even worse.
    The only problem pulling out the cables it is time consuming in you are down six cables, so my question is do any of you push in the camera on top of the cables.
    Also being Australian and with the expense of camera equipment I am smart enough not to turn on the drain machine with the camera inside.
    Simon
    Re: Seasnake and Drain cables in same pipe
    It would make me darn nervous trying it out. Wouldn't advise doing it. Plus if it ever did get tangled up apart from the cost there is also some current running down through there to power those LEDs.
    Has anyone else done this in the past. I am curious.
    BTW. welcome to the forum. Good to add to the number of Ausies.
      I wouldn't turn the cable while the seesnake is in the line. Think of what you risk by taking a shortcut.
        I have done it a couple of times . It makes me nervous as he11. I REALLY don't think it's a good idea.
        Yet I have, and probably will do it again.
        How much does a new push cable cost again?
          with jetting i pull the camera back a good foot before i turn on the water.
          with snaking i also pull back the camera once i have the blades at the point of interest.
          usually i will remove the camera, but there are times when i will leave it as it's a long push.
          as long as the drain cable is not bent, the is very little danger of damaging the seesnake cable. especially with water in the pipe to help lube it.
            I do this commonly with either the snake or jetter in the line. Don't rotate the snake (much... you can turn it over by hand a few times and be ok). The cables will wind up around each other and you have to pull them out together and unwrap them. Agree with Rick use caution with the jetter don't blast the camera head.
              Originally posted by Some Day Plumbing View Post
              Hi all
              Simon
              Your a braver man than I am Gung a Dim.
              Tony
                i've run the camera down the line with the cable still in but NOT turning. always retrieve the camera before cutting
                steve
                  I have done this when I am called to retrieve lost or broken cable as long as it is not too far.
                  I will push the new cable in and once I have gotten to the other cable I will watch and spin cable by hand until I have secured the other cable and then I will pull out the camera.
                  I use different things to retrieve cables.
                    Same here
                      I know it takes a lot longer but I snake I pull it out I run the camera in, I pull it out and I snake again then run the camera again!
                      Seattle Drain Service
