micro camera
  • micro camera
    hi all, can someone tell me if the price is right on this, i know 3 foot isn't long, but i need something to go through 3-4 inch traps, u bends, etc. would this also be bright enough with only two l.e.d.s to lght up a 4" pipe?thanks.
    http://cgi.ebay.co.uk/RIDGID-Seesnake-Micro-Inspection-Camera-UK-FREE-P-P_W0QQitemZ110286966720QQcmdZViewItem?hash=item110 286966720&_trkparms=72%3A12|39%3A1|66%3A2|65%3A12| 240%3A1318&_trksid=p3286.c0.m14
    Re: micro camera
    SeeSnake micro isnt a replacement for sewer and drain cameras. I dont think it would probably work for your application if you are trying to push through traps.
    Josh
      Re: micro camera
      3-4 inch traps shouldnt be a problem. Now W/C traps are a problem
        Re: micro camera
        Well you can get extension cables for it but they are pretty stiff and the couplings are large. I use mine for peering behind walls etc. also works pretty good for chimney and furnace inspection. It seems that the mini camera is more sensitive than the one packed with the see snake or is that my imagination?
        Peter
