Novice Needs Help
  • Novice Needs Help
    Hello,
    I am trying to use a Ridgid Kwik Spin but I am unfamiliar with this device and the owner of the device can't find the instructions!
    I'm sure it is simple to use, but I can't figure it out! I used a snake once before and the coil descended, then retracted fairly easily. . . this doesn't seem to do either (I know it's me)
    Thanks for any help you can provide.
    -Alyx
    Re: Novice Needs Help
    If the cable is not tangled inside the drum and the locking screw is loose the cable should manually extend and retract without any problem.
