Mini finds a gas leak
  • Mini finds a gas leak
    1-1/4" PE at sports bar feeding outdoor firepits. Massive leak - contractor couldn't even pump up the line for test.
    Put B/W mini (15/16" head) in at anodeless riser. BARELY made it through the steel stiffener inside the pipe at the fusion joint (thickness of stiffener reduced I.D. about 1/8").
    Image shows first of three "dings" in the pipe - one for each tooth of mini-excavator used to dig landscape wall where pipe was hit.
    Re: Mini finds a gas leak
    Excelent job Vance.
    Sorry no-one acknowledged your achievemement earlier.
    Some of us don't know when to respond unless we see a picture of someperson's face.
    So what is a steel stiffener? Are you refering to a transition fitting?
    I'm lost on this one
    nothin' new
    Last edited by drtyhands; 11-02-2008, 11:55 AM. Reason: I had to add a smilie to soften the mood...BABY
      Nice work!
        Excelent job Vance.
        nothin' new
        I think I mis-spoke on the fusion joint - that's what I tend to see most often.
        I think this is one of those newer mechanical PE gas fittings - similar to a G-union but specifically designed & approved for PE gas pipe. Since it works by getting tightened down, you need a steel insert inside so it won't just crush down the pipe.
        Image attached.
