Cheap camera for lite use
  • Cheap camera for lite use
    I am a contractor and I do quite a bit of odd plumbing jobs. I have been looking into getting a camera system for pipes,but I cant swing the 6k for a seesnake and I wouldn't use it enough to warrant spending that if I could afford it. I found an extremely cheap one at harbor freight and was considering purchasing it. I know it is far inferior to a see snake, but what would you guys recommend?
    http://www.harborfreight.com/cpi/cta...emnumber=93765
    Re: Cheap camera for lite use
    save your money and buy a used seesnake.
      If you can get a seesnake for 6 buy it now!!!!!!!!!!
        You generally get what you pay for.
        For your purposes, this may be ok, but for someone who uses it daily, no way. It'll never last, and the $500 price tag indicates it is on extreme closeout and you will never find parts.
        May be ok for you as it may last thru 20 jobs and let you see if a real camera tool is worth having for you.
          I doubt that camera head is even waterproof. Looks like it belongs in a toy box
            i bought my color campact from ToolUp, delivered to St. Croix for well under $6,000. had they shipped USPS i would have saved another $200.00+
            steve
              After only a few days on this forum I already know that any advice you give me is good advice, so im not doubting you.... What do you think I could find a used one for? I know the one from HF is far from a quality product, but they do have an exteneded warranty where they replace it no questions asked as many times as it needs to be. With out that warranty I would never buy any of their stuff
                check ebay. depending on the condition and model. $1500-3000.
                also if you need to locate the camera in the pipe, they have built in sondes. the receiver can be found used for $500 on up. some older models even less.
                  Welll, unfortunately, shoving a camera into a wet, nasty environment can never be called "lite" use.
                  What you meant was "occasional" use. Big difference. Even though you might not be using it on a regular basis, you still need the reliability of the SeeSnake.
                  I like the others' ideas about getting a used SS. That may be the way to go. You also DON'T need color or self-leveling if you need to save money.
                    You can find parts for that model. mainly parts from broken, returned cameras. I saw someone on Ebay selling them. That is what convinced me to avoid buying that model.
                      It is basicly the same as the "under water camera" they sell but a diffrent housing around the camera, and a push rod,
                        Sweets
                        G/C buddy of mine bought one out of absolute emergency needs.It did not even finish the job he bought it for,a rock in a three inch line.I think he said it was 750 bucks.Took it back same afternoon.
                          Sweets
                          Wow, that def. looks like something I should stay away from......
                            I know which one you are talking about, I bought one for a small job and it died the first time througha 4" cast trap. Harbour freight replaced the unit since it was one day old. The second one heats up and looses video after 5 minutes. Unit it only good for straight clean 4" pvc. I bought the seesnake self leveling, lcd, 200' color, d.v.d. -----my troubles are over.
                              I found a cheap camera which may work for you and it already has a simple USB interface for the computer.
