seesnake camera. i cant see anythng?
  • seesnake camera. i cant see anythng?
    my camera turns on i cant see anything? it was working fine the locator works. i just cant see a picure. can i fix this my self or do i just replace it my self? or what could be wrong.?
    Re: seesnake camera. i cant see anythng?
    the good thing is the locater working. at least you're getting power.
    it cold be the inner connect cord to your monitor, the monitor, the camera head, the slip ring in the reel, the transmitter.
    what you need is another monitor to test this against. do you have a friend with the same camera to test it with?
    if not, the local service center can easily diagnose it.
      Thanks, but I dont think I do know someone whith the same unit. Do you think it's something I can try to remove and try to fix? Or just try to take it to a repair center? I belive that the head was banged up during a trip to another job. So I don't know if hitting the headline that is what caused the problem
        Give our tech service guys a call. They will have you run some diagnostics on it to try and get you fixed without having to send anything back. It may be something really simple.
        1-800-4RIDGID
        Josh
          Ok I will early tomorrow thanks guys!
