Terminating see snake wet end
  • Terminating see snake wet end
    Does anyone have any service info for terminating the large camera reel see snake wet end. Have the replacement kit just need a service manual to do it correctly. (this is well within my capabililities as an industrial electrician and gas fitter).
    thx
    Lambeater
    Re: Terminating see snake wet end
    I know of a guy that sells re term kits for a General gen eye 2. Same exact thing as the gator cam 2 but different colors. He was referred to me by Gator cam rep. Not sure if he has anything to do with Ridgid stuff.
    He's in Canada. I'll hunt for his info and post when I find it.
    According to him re term is not that difficult and his kits come with full instructions.
      thx
      Lambeater
      from what i know, it takes special proprietary tools to do the crimping and then the water testing requires a special jig to pressure test it.
      probably not worth the risk for 1 job. take it to your local authorized repair shop and let them do it. a couple hundred dollars is cheaper than a new camera head if it leaks.
        Confirmed. Re terminating is not an easy procedure and it does take special tools.
        Josh
          Josh
          Hmm....I wonder...
          Why do they allow us to even buy the reterm kit?
          Doesn't make sense...
          The camera head is sealed separately from the cable - it's water in the pushrod core where the individual conductors are that you are trying to avoid.
          However, my local dist. retermed a Mini cable for me a few years ago and warned me it had gotten wet inside and that I need to be aware of that.
          Still going strong with no problems.
            You may be right Rick to a point, but unless Ridgid tech support supplies the service info to ensure that it is done correctly and with the right tools we will never know. The sad thing is for the small amount of times that we have had to send our equipment away to be repaired we have always been without it for at least a month. The other 95% of the time I have repaired it (yes I do have extensive equipment repair experience).
            We also have a large Ridgid equipment inventory. (3 large color camera's and reels, 1 color mini cam, 1 navi trak, a scout, 1 m-scope locator, many ridgid drain cleaners, a ridgid jetter etc and the list goes on).
            thx
            Lambeater
