In-Pipe Root Blockage Pics - Have any?
  • In-Pipe Root Blockage Pics - Have any?
    Any of you guys have some real good root blockages images from inside the pipe. I am trying to put together a presentation and I know I have seen some good ones on here in the past.
    Thanks a lot guys. Dont feel bad if none of you have any pics. Ill get by
    Thanks,
    Josh
    Re: In-Pipe Root Blockage Pics - Have any?
    josh, how do i get stills from a vhs video tape?
    do i convert to dvd and then somehow take a still
    i have lots of stills for the roots i've removed
      rick just go and put a lot of roots in your pipes then take a picture
        or just have Joey do it for you
          Josh,
          I have some good video if you want. I'm sure you can edit it how you need to or harvest some still shots.
          Want me to send them your way?
          www.firstresponsedrain.com
            Ya gotta be one of those nerdy computer guys to know how to do it. DVDs are pretty easy.
              Jake, thanks for the offer. They wont make it here by the time I need to present.
              Some day I need to build up a library of inspections here as samples. I just have some from Rick's ring exploration all the ones we have here are boring pipe.
              Thanks guys,
              Josh
              Originally posted by jrsaltz View Post
              Josh,
                You betcha:
                http://www.detectionspecialties.com/...gallery_p1.htm
                Right click and copy.
                I can get bigger ones if you want - how much time do we have?
                Vance
                  "Your One Stop Shop for Root Instrusion Stills!!!"
                  (I have near-on-line digital storage of every inspection I have done since
                  12/1998 - I keep the tapes at the shop, the disks at home. You're in luck guess where I am...)
                    What 11 years of inspections (1600+) stored on optical media looks like...
                    (recent ones are stored 5 to 10 at a time on DVD depending on size - older ones stored 1 at a time on CD-R)
                      could you possibly pull some off of Youtube videos?
                      http://www.youtube.com/watch?v=398yhFbdPis
                      http://www.youtube.com/watch?v=jxiY1...eature=related
                      more at youtube
                        Here are some more pics of root intrusions:
                          You guys are the best!!!! Thanks a million. Very cool library Vance and some great pics. Good stuff Jake. This should suffice for my presentation. Make sure you hit me up for a calender at the roundup.
                          Thanks again,
                          Josh
                            Vance, I'm not sure what the data storage life is for a DVD but I read an article that folks are loosing data on CD/R's due to age degradation (8-10 years)
                            I did not know that CDR's had a shelf life, I'm going to guess that DVD's are the same... I hear folks are shifting to online storage to help avoid this)
                            Okie
                              Okie:
                              Yep, I am aware of that problem. It has mostly to due with storage conditions (temp, humidity, stored flat on top of each other not in Tyvek lined envelopes) etc. I am keeping up on things in this regard. I have CD-R's with data on them that are older than when I started storing video by several years. I throw a few (from diff. mgfrs. of media) into several different optical drives (important: some drives and or media will show problems before others) on a regular basis to see if it will still read.
                              Can't trust online storage either and it costs too much for large video files. Also takes forever to down/upload on "consumer" internet connections.
                              If I were the CIA, storing mission-critical data, I might think differently. But paying attention to storage as well as having two copies stored in completely different places (in case one burns down, etc.) will have to do for now.
