How To Post Images
See more
See less
Color or B&W?
  • Color or B&W?
    Color or B&W? Why?
    Thanks.
    Re: Color or B&W?
    color. It looks more professional, and makes it easier to identify pipe materials, and debris in the pipe.
      Re: Color or B&W?
      Color or B&W? Why?
      Thanks.
      I've had both and I prefer the color because it is easier to identify changes in pipe type and the difference between a shadow and a problem. To be honest either would be better than not having anything at all. However, if you go B&W you will always wonder what color would have been like (read secretly wanting to replace it) and if you go color you will not miss B&W.
        Re: Color or B&W?
        Go with color. We started with B/W and when we switched to color we couldn't believe how much more you could identify during an inspection.
          Re: Color or B&W?
          Color - for the same reasons SG and others mentioned
          Lenny
          Pronounced A-Bear Drain Care
          I know, it doesn't make sense.
          http://www.hebertdraincare.com
            Re: Color or B&W?
            started with b&w as color was not out yet due to lack of white led's.
            nothing was wrong with b&w as it had a good grey scale effect.
            now with white led's the lighting is so much better than before.
            color does let you determine corn form peas
              Re: Color or B&W?
              I'm sold! Thanks!
