Need to camera 12 inch line...
  • Need to camera 12 inch line...
    Crap! I only have a mini, but is it possible? I only need it for about 50 feet. This is a common run off drain handling rain & irrigation water. This community drain runs along the back of my Customers home and backs up when it rains heavily.
    Re: Need to camera 12 inch line...
    jeff, the mini is rated for 6'', but i stop at 4''. the lighting is too weak and the push cable is to flimsly for 12''.
    now if you attach some additional led mag light and use a good spacer to hold you centered along with a pull rope, you might get a decent picture.
    even the standard seesnake will strugle on 12'' pipe with all the suggestions i've listed.
      Thanks Rick
      Yes, that was my concern also. I'll take that as a confirmation
        General makes a roller skid to do 6'-12" it works pretty well. It also has 3 mounts for auxillary lights that are available as well. Hope this helps.
          ask S&D what they use, they have a little robotic one that seems pretty cool
            SAY WRENCH WHO MAKES THIS ROBOTIC CRAWLER. I AM IN SEARCH FOR ONE.
