Micro SD Card
  • Micro SD Card
    If you put an SD Card into the Micro does it format the card for only it's & cause some problems if you were to try and use it in another media device?
    Re: Micro SD Card
    Whatever device you put it in will re-format for it's own use, but you will lose any stored data from the previous device when the card is re-formatted.
      Re: Micro SD Card
      I just pulled the SD card out of my explorer and put it in my digital camera and back again. I was able to use and view pictures on both.
