Scout Locating
  • Scout Locating
    What are all of the things a Scout can locate?
    Using a "brick" or other transmitter?
    Thanks.
    Re: Scout Locating
    from what i remember a boy scout can locate girl scouts
      Re: Scout Locating
      And my boot can locate your a$$ cowboy!
      (Pretty good though )
        Re: Scout Locating
        and my phone a friend can give you a time out
          Re: Scout Locating
          Rick,
          Please quit picking on JC.
            Re: Scout Locating
            Seriously, does anyone locate things other than sondes or camera heads with one?
              Re: Scout Locating
              Sorry I have the Navitrack. I'm sure they are very similar though. Mine will locate pretty much everything I need and then some with the exception of non-metallic pipe.
                Re: Scout Locating
                Yes I've got a scout and the 5 watt red brick and use it to locate water pipes and works like a beuty it has 33, 8 & 1 khz frequencies I normally wet the ground and push the earth spike which comes with it, and clamp one connection to it and the other onto the pipe I am locating and then select the frequency and adjust the scout to that frequency and off I go, but it sure as hell goes through batties,
                Tony
                  Re: Scout Locating
                  JC
                  When I asked about using our scout for locating utility lines or tracing I was told that the scout was made for locating sondes and would not be accurate in locating using a brick. We purchased the SR20 to use with a brick. The SR20 has an omni directional antenna setup to trace the signals accurately.
