The brick and line trace box
  • The brick and line trace box
    I see the brick and the line trace navitrack box. I understand both can energize lines for locating metalic lines. I currently use the box with the handle (larger one) What is the difference between the brick and the other one? For residential use do they match up?
    Re: The brick and line trace box
    the full size red navitrak line transmitter #14818 is a 10 watt variable output. on 4 frequencies and 1 watt on 2.
    the brick #20168 is 5 watt and is missing 128 hz. and 200 khz.
    depending on your application, the red brick might be all you need.
