recording
  • recording
    how many of you are recording? i was thinking of going with a mini and a minipak monitor. and then breaking out a regular dvd recorder when asked for a record. i'd keep costs down. that would alow me to get the microdrain as well.
    what are your thoughts?
    the only dumb question is the one that is not asked!
    Re: recording
    Its to cumbersome having to arrang and connect recorders, and monitors on a job its better with the monitor and DVD recorder in one it might be cheaper at first but you will be kicking yourself later on.
    Tony
      Re: recording
      look into getting the new dvdpack. has a sony dvd plus the lcd screen and power supply ac or dc battery pack.
      plus it has push cable trace ability along with the camera head trace ability.
        Re: recording
        Start off with the MicroDrain/Explorer combo unit. That does 90% of my camera and recording. So quick and easy. No wires or separate equipment to deal with. Be sure to buy the new add-on microphone module for voiceovers.
          Re: recording
          i'd have to get the OLED it can get to -40 here in the winter.
          Mini-SeeSnake Plus at 200 ft. and the OLED recorder? good combanation?
            Re: recording
            for portability and record-ability, it doesn't get any better.
            team that up with the 18 volt battery pack and you're good to go.
            the mini seesnake will get you 90% of 1.5-6'' lines. distance will be dictated by changes of direction and pipe friction.
              Re: recording
              You may have already figured this out by now,but just for the record...
              A large enough number of your sewers are long runs 2-300' plus they come out of the back of the house for an old septic system then back around to the street which gives you a minimum of three 90's on 3" right out the gate.
              A 200' Mini may go 200' as a miracle 10% downhill grade,soaped up 2" A.B.S. run with no offsets(Ha-Ha).In other words It ain't gonna help you much after 75-100'
              If your looking to go 200 you will need the "200 Plus".
              No need to get the 300 it won't push.
