What Kind of Locator
  • What Kind of Locator
    What kind of locator do use use to find sewer and water lines buried with foil marking tape. Is it better to use a tracer wire?
    Re: What Kind of Locator
    I'm pretty sure no locator will "hit" accurately on foil marking tape. A tracer wire would be better.
    And you would then need Navitrack Scout and Navitrack Brick at a minimum in the Ridgid Line.
      Thanks JC. I have never used the foil tape before. Only dug it up. For some reason I thought you could locate that stuff. I will stick with tracer wire
        We always had to place the foil tape X number of inchs above the burried pipe or wire as a "Hey you are getting close to something"
