Color vs B/W Cameras
    Re: Color vs B/W Cameras
    The microReel camera head is now 25mm. The compact color head is 30mm. The 2 systems are very similar apart from form factor and monitoring options.
    The old black and white compact heads used to be 25mm. So now color is as small as black and white was.
    Josh
    No offense taken Northern... just making sure you guys understand some of the motivation behind the decision.
      Josh
      Now if we can get the full sized color systems down around the price of a full sized B&W that would be the awesome.
        Does the micro inspection spring scratch toilets?
        Seattle Drain Service
          Originally posted by Cuda View Post
          Does the micro reel spring scratch toilets?
          The Micro reel can not go through toilets. The push rod is too stiff.
            Micro this micro that, compact etc. I think they need to rename them all starting at the bottom because a compact ain't really the compact anymore
              Doesn't matter just saw the toilet guide.
                The Micro Drain can go though water closets, the new Micro Reel can not. And yes the guide is pretty slcik. Got to play with that at the round up.
                • #23
                  have a brand new 325' b&w full size seesnake still in the box. let the bidding begin
                  also some other used color 200' seesnakes and a b&w mini 200'.
                  • #24
                    Send me a pm on how much you want for a color 200 seesnake fullsize.
                    Black and white mini too!
                    • #25
                      Guys, thanks a lot for your help! Your replies helped me make up my mind. I will post what I bought in a couple of weeks.
                      • #26
                        Just wondering how much for the 325' full size. And is it a true blue unit?
                        • #27
                          Hey Rick, Let me know what you're looking for for both of those reels.
                          -Chris
