What would be best for My Usages?
  • What would be best for My Usages?
    Have naitrack system with both small and large camera. Also large screen dvd burner. Would like to add a line locating transmitter. need to be able to Locate Steel and copper under dirt and concrete up to five feet deep. Is the Navitrack line Locator worth say 600.00 more then the Brick, or will the brick work well enough?
    Re: What would be best for My Usages?
    What do you mean when you say you want to locate steel, copper, and concrete under dirt?
    I think the brick would be fine depending on what you're doing.
    Applying a signal to the metal and just setting the locator to the right frequency.
      Pipe of course water lines and gas lines
        The Brick should be fine for the metallic lines & tracer wires.Watch the videos on the Ridgid website under the locating section. Educational and helpful.
        Good luck.
