Ouch Cut my compact head off at the spring
  • Ouch Cut my compact head off at the spring
    How do you remove the camera? How do you remove the spring? Can this be fixed with out sending out the entire camera reel?
    Compact Seasnake, Cut the camera off at the spring
    How do I take off the camera and spring? the cable is red.
      Re: Ouch Cut my compact head off at the spring
      If the push rod is cut it has to be reterminated it takes a compact reterm kit and the equipment to do it. Marvin
        To remove the camera head you will need the spanner wrench tool that came with your seesnake. If you did cut through the cable you will need the retermination as stated above. We have a company in Louisville called Pipe Eyes that can do the repair for you. If you would like their contact info send me a PM or look at the service center listing on the website under inspection.
