Archos 705 and seesnake
  • Archos 705 and seesnake
    So I got my archos 705 yesterday. A little disappointing. I think it's defective but I thought I'd post here and see if those of you who have them know what's wrong in case I'm just being dense.
    Screen won't come on. Little green light on the on/off button lights up green when I push it, but the main screen just stays black. Charged it overnight, no difference. Think the charger is working as, with the on/off button dark, when I plug it in it lights up green. Pulled the battery and pushed the hidden reset button behind there, no dfference. Is it just broken or am I doing something stupid?
    Re: Archos 705 and seesnake
    I had the same problem when I bought one of these for my daughter. I ended up returning it and getting her a 30 Gig Zune. I think it was OHS (operators head space) in my case as well.
      I have 2 of the 705's the screen just comes on. The only time it is not on is when I have it in the cradle hooked to a TV and I push the lower button below the on button then it goes off till I hit it again, but that does not sound like what is going on.
      Seattle Drain Service
        Also when you turn it on the screen says Archos while it boots up it is Linux os underneath.
          You ARE pushing and holding POWER for about 5 sec, right?
          Just a quick stab won't do it...
            push and hold, after ~1sec green light above power button comes on. hold longer no diff
            push and hols ~15 seconds with green light already on, green light goes off.
            never been able to make it do anything but light the green light.
            manual says 'chg' should lite up while charging, and go blinky when done. never lights up. but plugging it in with green power lite off does turn green lite on.
            talked to vendor today they are to send me another and a call tag for the first.
              Ace you ever get a new unit and do you use it?
