counter/transmitter installation question
  • counter/transmitter installation question
    Hi guys,
    Can you add the new counter feature to old B/W reels?
    How difficult/expensive is it to install a transmitter?
    trying to soup up an old faithful friend a bit more
    Re: counter/transmitter installation question
    transmitter will run you around $550. pretty simple all you need is the spanner wrench to remove the camera from the spring. the rest is pretty simple was the cord ends will mate and eliminate the jumper cord / inner connect, between the camera head and spring.
    if the reel never came with a count-r or count-r plus, you will need some work done to the hub. not sure the cost for this.
      Thanks Rick
      I've rented mini reels with the count-r +. It's a lot slicker than my colored electrical tape! Seems like it could be done with some patience though.
      Is your wife feeling better this week?
      -Chris
        yes she is, thanks
        actually i've done electrical tape for years and years.
        red=10'
        white = 20'
        blue= 30'
        yellow= 40'
        green=50'
        then it repeats
        the new count-r plus is pretty darn accurate now
