which camera?
  • which camera?
    Ridgid colar compact with 100 feet or b&w mini with 200 feet?
    Re: which camera?
    The mini B/W would be my choice because of the stiffer pushrod and B/W is fine. And the 200 ft is a real plus because of 125 ft sewers and because it can be repaired and cut down and still be used , you cut down a 100ft and get to 66 and you won't be able to do a lot of jobs.
    Seattle Drain Service
      Re: which camera?
      I too would go with the black and white. If you do a lot of dye testing of drains and need to see the colors then go with the color system.
        Re: which camera?
        i guess you're buying a used system as the b&w mini ss is no longer avaliable.
        i too would go for the b&w mini 200' if you can find it. otherwise get the 200' color.
