New cutting wheel
  • New cutting wheel
    Hi All
    I have a old Ridgid pipe cutter found at father-in-laws after he passed away and I need to replace the cutting wheel
    Its a #0
    5/8 to 2 1/8 cutter
    it has the inside pipe cleaner attached to the body of the tool
    onlu other numbers I could find was the 1934 US pat. numbers
    Anybody know where I can get the cutting wheel....??
    Re: New cutting wheel
    I would suggest to take it with you to a quality hardware store or a plumbing supply house and see if they can match it up with some thing in stock,
    I did a look and did not see a model "0" listed, in my catalog, (may be I jsut not be locating it),.
      The "0" tubing cutter was introduced in 1929 and discontinued in 1956. It used the same wheel as the current #20 cutter. The catalog number for the cutter wheel is 33160. Any Ridgid distributor can get this wheel for you. Hope this helps you out.
        Yes it does thanks for the info........!!
