Seesnake micro wiring
  • Seesnake micro wiring
    The head broke off the imager cable. I was able to disassemble it and prepped the wires for resolded. My problem is I have 5 colored wires, but no residual wire left on terminal to figure what color goes where. I broke out my tiny aligator clip jumper set and ready to start checking voltages, but hooking up will still be shot in dark. I'm bound and determined to make this work. Looking for color order.
    TIA
    Re: Seesnake micro wiring
    you need a new 3' cable with imager head. contact ridgid customer service for a possible replacement.
    what color was the head? black or orange?
      Rick,
      Are you a Ridgid rep? You know, on the side.
        Originally posted by geno gardner View Post
        Rick,
        to this day, ben/ gearjunky thinks i am even though we have been friends for a few years and have done stuff together
        what gave you that idea
          I'm with Rick on this one. You could probably try your local service center - http://ridgid.com/Tools/Technical-Services/EN/index.htm and order a replacement through them or contact Ridgid directly - http://ridgid.com/Tools/Contact-Us/index.htm and ask them about ordering a replacement.
          Ideal Plumbing
            See if this post helps:
            http://www.ridgidforum.com/forum/sho...ighlight=wires
              Thanks Vance G. I was getting frustrated by all these people who would rather buy a new tire than fix a flat.
                didn't tell you to go buy 1, told you to contact ridgid customer service.
                and once you put all the stuff back together, how to you expect to keep it from breaking and still maintain the water tightness
                i guess since i own 3, i'm 1 away from a full set
                  Yup...like Rick said. Chances are it won't be water tight after a repair but if you can get it back together and make it water tight, then by all means, you go right ahead.
                  Ideal Plumbing
                    Call Tech Service
                      Tech service was the first place I called. They said all info is propietary and that i should buy a new tire. That's why i came here looking. I'm satisfied with the answer I got, and Probably will have it finished in next few days. Have too many projects going right now, and work on them during the commercial breaks watching the football games.
                        See attached photo. Mine broke off also and I was able to repair it.
                          I know this is an old thread but I am looking for the picture of the pin out in the last post which is now missing, any help would be great.
                          Thanks.
